Page 2 of 16 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 159
Thread: Astra VXR FAQ
  1. #11
    30th July 2006
    403
    Quote Originally Posted by Crafty View Post
    What isnt on any vauxhall ?
    The way you've wrote it implies that the car has a variable ratio steering rack, which it doesn't. Pressing "the switch" Reduces the power assistance given to the rack, and so the wheel is a bit more weightier and improves feedback from the road - That's how I understood it anyway.
  2. #12
    VXRacing ahead
    30th January 2006
    718
    Quote Originally Posted by Rob H View Post
    Dont think this correct either, the weight is added and the amount of turn is reduced.
    Im sure someone will confirm and give the technical info
  3. #13
    12th August 2007
    42
    Sorry if this is in the wrong thread or section, but can someone tell me what this "stepper motor" thingy-ma-jig is,and what it function is in the speedo????
  4. #14
    21st January 2007
    2,185
    Just got back to this thread..
    I dont know for sure but I suspect that the way its done is that the steering ecu looks at the steering column angle sensor with sport off if it sees say 10 degrees of movement it tells the motor on the rack to assist the steering so that the wheels end up moving say 20 degrees.
    With sport turned on it does exactly the same but less movement of the steering angle sensor (lets say only 5 degrees) still results in 20 degrees of wheel movement.
    Be interesting to find out for sure.
    Dave, not quite sure what you mean, I suspect the speedo needle is driven by a stepper motor - cable speedos are a thing of the past.
  5. #15
    23rd October 2006
    1,531
    Quote Originally Posted by DaveR View Post
    the stepper motor is when you first turn the key in the ignition and all the needles shoot round to max,preety cool i think
  6. #16
    12th August 2007
    42
    Quote Originally Posted by vauxmad View Post
    My Cougar did this if there was a problem somewhere, that indicated that the ecu was re setting itself! :eek:
    Cheers anyway
  7. #17
    23rd October 2006
    1,531
    Cheers anyway
  8. #18
    8th December 2007
    4
    does any one know where i can get a fascia plate so that i can fit my stereo in and take the factory fitted on out
  9. #19
    VXR Torque of the Devil Dazturbo6502's Avatar
    21st February 2006
    7,953
    Can be bought from most Audio SPecialists, or failing that, try E bay
    <a href=http://s39.photobucket.com/user/dazturbo6502/media/dazCustom2.jpg.html target=_blank><img src=http://i39.photobucket.com/albums/e156/dazturbo6502/dazCustom2.jpg border=0 alt= /></a>
    My VXR from Start to Finish
  10. #20
    8th December 2007
    4
    the only thing is its the 08 spec so i dont no if its out yet
