how to block OEM recirculating valve?
  • how to block OEM recirculating valve?
    can anybody help me ? a need some instruction on how to this... I ve put Forge blow off but I can still hear the factory recirculating valve...
    ---Astra OPC arden blau, 18" snowflakes, Sport IDS+, AFL, CDC40 Opera & CID...
    ..Wiseco forged pistons, FCP Engineering steel rods, ARP head & rods studs...Cometic head gasket...ACL bearings...Wiltec large FMIC
    Forge blowoff valve, Straight through backbox, 2,75" EDS downpipe, 1.9 CDTI airbox conversion & K&N filter, NGK Iridium plugs, Eibach Pro kit
    Did you fit one of these? http://www.forgemotorsport.co.uk/con...roduct=FMBPVXA
      what he said ^^ you need one of those
        lol... no I didnt... just bought it !
        now can someone give me a picture and show where is the that valve that I need to replace with this one ? tnx a lot !!!
          http://www.vxronline.co.uk/forum/showthread.php?t=64122
          have a look at this thread, pics and a guide there although that says its for the recirculating valve its the same procedure for the blanking cover
            thanx m8 ...
              I have another question so I ll put it in this topic
              when I installed forge blow off it was very loud ( psssss ) in the begining, and I havent been driving OPC for 9 months...now it doesnt sound like before...I can barely hear it...and it isnt that loud pssssst sound, its strange...like I have a little duck inside...
              what could be the problem ?
                  Potentially you have a pipe off your inlet have you checked them all. The noise you describe could be your turbo blades stalling.
                  Have you fitted your forge blank yet? Did you block of the pipe that originally went into the recirc valve?
                  | Find | Watch | Follow |
                    I am still waiting for forge turbo blanking to come. I ll check now every pipe
                    but I have the sound I want ( loud psssssst ) only when I rev it up to 5000-6000 o/ per minute in neutral ... but in driving I got a small duck under bonnet
                      If you are lookin to buy a blow off valve ... http://www.vxronline.co.uk/forum/showthread.php?t=93386
                      Astra Edition #105
                        thanx mate...I ll try to do this afternoon...and let you guys know the result
