ive looked in to this mate was told no more then 5mm and if you want spacers and you are looking at new wheels then team dynamics can do you the wheels with the spacers sort of built in. thats what im guna get but all round
I m running with 15mm eibach hub centric wheel spaces front and back with standard 19" wheels and eibach sportline springs with no rubbing or any other issues . It now handles a lot better with the 30mm wider track and it also fills the arch's nicely . You will also need longer wheel bolts to go with them .
Project J is here Carbon Parts for Astra JOr vectra vxr brake conversions to astra/corsa please PM
gotta agree your wheels sit very nice in the arches with your set up
Any ideas why Vauxhall make the off set of the wheels as they do, if car handles better with 15mm ofset change you would think they would fit them as standed, also why did you go for the Eibach one i would have thought with your line of work and skills you would knock some up in no time.
can t answer that one but why didn t they do alot of things , the opc performance centers used it as part of there handling setups ( not sure what size though ) also wasn t the nurburgring track slightly wider than standard ?
as for me making them i just didn t have the time as i needed them in a hurry and it was a lot easier just to buy them although they did all start at 20mm so i have done something to them
