hi everyone first time posting on this site and i need some advice, i have a astra coupe turbo and i have just finished a garrett turbo conversion with tubular manifold but i am unsure where you get the take off to work the wastegate actuator and what do you do with the pipe that used to go to the internal dump valve on the old vxr turbo? your help will be greatly received
Originally posted by rccoupe View Posthi everyone first time posting on this site and i need some advice, i have a astra coupe turbo and i have just finished a garrett turbo conversion with tubular manifold but i am unsure where you get the take off to work the wastegate actuator and what do you do with the pipe that used to go to the internal dump valve on the old vxr turbo? your help will be greatly received
if you have a 3" inlet and 2" outlet compressor housing you may have to weld on a bung like i have had to,otherwise you can only pick a point up near the discharge end of it.
if you intesnd to keep the stock boost control solenoid,you will also need to tap it into the inlet side of the turbo aswell.
garrets dont have built in dump valves like the stock turbos do so you will either have to run a bailey dump valve or an after market recirc valve.either way you want to run the stock hose to the dump valve to allow it to work properly....superior horsepower through knowledge,good design and maximum efficiency
