Bell housing oil leak
  • Bell housing oil leak
    Well did abit of work on the car yesterday only to fined there is oil leaking from the bell housing well i think its oil as its the same gold colour as my engine oil. and it [email protected] out we cleaned it all of i drove the car for about 45min and its covered again.
    I just hope the rear crank oil seal has failed and nothing has cursed it to happen but the cars only done 24k!!
    at least my clutch is not oiled up and slipping yet but i carn't see this been a cheap repair.
    does anyone know if the rear crank oil seals are prone to failure on the astra vxr's?
    any input would be great
    Thank i will be a phone call to Ian at MPG tomorrow.
    Thanks Adam
    just been out and dropped some oil out of it in case it was over full i don't think this was the case theo but might as well give it a go.
      hope you get this sorted soon fella , hopefully it aint related to the 3 gauge conversion in anyway??
      Arden Racing Edition
        The fact you had more oil in it may have stressed a seal and subsequently made it leak
        | Find | Watch | Follow |
          Bump on an old thread mine now has this its the main rear oil seal right ?
          thats what courts said anyway gearbox out jobbiw to replace a £25 part ....
            Nothing else for it unfortunately, its one of those jobs that takes a lot of stripping down to fix such a small issue.
              Sounds as though you answered your own question as it sound like the crank shaft oil seal.
              hope it doesn't work out to be to expensive good luck.
              Would like to do more,
                Thanks Adam
                Check the breather from the crank casing aren't blocked before taking anything apart, as to much pressure in the crank casing can push oil true the rear crank-seal.
                Click Follow Me on Facebook
                  im off to vxrdaves house tomorow to have a look any chance you could perhaps descibe a little more where this is ? im very simple perhaps a pic thanks
                    Had this on my old vxr, was the rear crankcase seal.. If it is, it's a gearbox off job iirc
                      its like a £450 job for a £25 seal
                      lightweigh flywheel aswell while im in there me thinks
                        thats right mate mine was done under warrenty. was a good thing really as i can no way afford £500 at the mo
                          try doing a crank seal on a 16L V8 thats Fun with its gearbox
                          the truth is out there
                          part GSI part VXR
