Just a quick question: Will the EDS handheld and software run ok on Widows 7, Running Virtual XP?
EDS Software
they have updated it now so you can use vista and 7 also
a little bit
done mine, the missus's and the neighbors too
No sometimes you may need to update the ipf module it self. Most people who have bought the ipf have had to do the update first to the ipf module.
Well i know i did.
The module isnt connected to laptop when writing or reading car. Also you only have to read the car once and when it promts you to go to car and plug it in just unplug and replug then it will come up with your ecu info and allow you to continue. This next step will show ur maps you choose map you want click continue it will download map to ipf once done disconnect from pc and then plug it in to car and switch igniton on and leave it for about 20-30mins intill light goes solid green.Last edited by donovan2123; 27 July 2010, 10:48 PM.
Originally posted by donovan2123 View PostI made the mistake of keeping it connected to laptop whilst plugged in to the car! This caused ipf not to work. Once i figured out it must not be connected to laptop when connected to car it worked fine.
Originally posted by Dab_vxr View PostI dunno if i can be arsed with the hassle as my laptop and netbook doesnt have an R232 conector, and ive heard the usb coverters are unreliable, plus ill have to **** about reinstalling a prehistoric OS just for that
