What width are they ??
As going from 225 to 235 is just an inch difference ??
There is a list of what will fit on what and you would be susprised how wide the range is
for specific rims HTH.
Would like to do more,
I was trying to help mate as I have in the past had a list of how many different width tyre's wil fit one rim size, and the list was vast.
The difference between 225 & 235 is one inch and I find it hard to believe that a manufaturer would put the maximum size tyre on a rim as this does not give you much leeway for something going wrong ?
By the way if I had the cash I would have had the wheels off you my self.
one inch,noop.
a 225 is 225 mm wide,a 235 is 235 mm wide.to me thats 10 mm and a inch is 24.5 mm.
so 10 is fine,mine is going to 235 40 18 next time it needs boots
