My Scorpion is on the way ! What about turbo clamp ?
  • My Scorpion is on the way ! What about turbo clamp ?
    Hello,
    My turbo back Scorpion is on the way ! I would like to use a brand new turbo clamp but I can't source locally the original Vauxhall but only generic 3" V-Band Clamps like this:
    http://cgi.ebay.com/ebaymotors/OBX-S...ht_1818wt_1165
    Is this one fine ?
    FD
    That's what mine looked like apart from it had a spring on the thread bit. Tension spring I believe.
    Why can't you source an original vx one?
    Black Astra VXR, 19" Diamond Cut alloys, 3" Turbo back Scorpion exhaust
      enjoy bud, if youve never had your clamp off b4 you will be fine with your normal one..
      if not ring mattibibs hel sort you out
        It was off once when changed turbo.
        I can't source locally because not living in UK now.
        This is the original one:
        So, will it matter the loading spring ?
        Marc
          shunt do mate, am sure mattibibs wil post abroad also mate
            I've always had the same clamp which has been on and off a few times when changing the turbo and exhaust etc.
            Clique #14
              same for me i dont chaung them unless needed
              the truth is out there
              part GSI part VXR
                mines been off a few times and it still fine.
                  depends which garage takes it off and if they take it off with care.. mine was bent to hell so i bought one from mattbibs..
                    same ere, plus i already got one just incase so there was no complications
