program on board comp. to show temp., boost, and anything else???
  • program on board comp. to show temp., boost, and anything else???
    Ive got sat nav built in unit and was wondering, can u program on board computer to display on screen engine temp. and boost levels on screen??? Cheers for ur help on this
    you can get it to display engine temps but not boost levels.
    When you are on the music screen hold down settings until it bleeps and says testmode on
    then press BC 5 times and you will see the engine temp.
    Go back to the main screen and hold settings to get out of testmode.
    This is how you do it on my CD70 but may be slightly different depending on your unit.
    Look in the how to section if you cant work it out mate
      I tried using an elm327 obd tool to data log but it wouldnt even read boost. Anyone had any success reading boost from the engine with obd?
      Arden Astra VXR
      Stage 2 - 289bhp Blueflame Exhaust & Remap
        you cant read boost though obd
          ***** can read boost but not with generic OBD stuff.
          Clique #14
            What logger do you use to read boost with *****?
            Arden Astra VXR
              Cheers, was hoping u could program it to show on screen permenantly instead of mpg data. Just would've look good with on screen digital boost levels and temp. etc
                I believe ***** can read it but only as kPa (kilopascals)
                Originally posted by soosie
                  Cannot be done with the factory stuff but if you convert the CID to display video, you can get a specific make logger to show on the CID.
                  Who makes this I am not saying as I want the first one they make, but lets put it this way it costs in excess of £500.
                    Cant a dashhawk not display all these figs for you ?
                    If so, its a real shame you cant send the display o/p to the CID
                      I'll find a way soon enough get some of my computer tech head mates on the case
                        Not boost, I bought one and hoped it would display boost, but it didn't, , I have also got ***** and yes I think it can display boost in kPa but how annoying to have a laptop on the passenger's side.
