nothing to be worried about its a common problem its the cim module mine comes up from time to time if your not having to many problems starting the car dont worry about it
how old is the car the cim module is a unit in the steering colum that controls the engine imobiliser and the buttons on the steering wheel and the stalks at some point you will have put your key in the ignition and the car wont have started you must have turned back off and tried again this is a very common thing
You don't need to fix it mate, there's nothing to fix! It has had a fault once and logged it, those codes will stay there until they are cleared ie tech 2 or you unplugging the battery. If this was constantly happening then you would need to get it sorted.
Stop panicking mate it's nothing to worry about!!!
