Am going to change the front discs and pads as the insides of the nearside disc is quite badly scored. Am also going to change the brake fluid. Can anyone tell me what amount of fluid will be enough?
How much brake fluid will i need?
i also need to know this so i know how much DOT5.1 to order!
Originally posted by Dab_vxr View PostLooking on the Opie oils site, and it says dot.4 for Astra vxrsigpic
Arden Blue Astra, 19's, Bluetooth, Full Leather, Stage 2 Ready
Wanted: 18" Black Wheels, maybe an FMIC and Stage 2
exactly as red ice said! the dot5.1 is an upgrade and like a pound cheaper so worth it!
my 4.dot is a better spec then most 5.1's
why do you want to run 5.1??
have a look at euro car parts for
ATE super blue from a vauxhall tuners
http://cgi.ebay.co.uk/Ate-Super-Blue...5604c6ffecbe62the truth is out there
part GSI part VXR
To be honest, unless you're running it on a track, DOT 5 brake fluid will cost you more money (even if it is actually cheaper to buy).
DOT 5 is more hygroscopic (ie, it absorbs moisture faster) than DOT 4 so you'll end up needing to change your brake fluid (about) twice as often to keep optimum braking performance.
Stick with a really good quality DOT 4 - if you've got standard discs and pads these will reach their temperature limit way before the fluid does.Sold - Arden Blue Astra VXR on 19's
Originally posted by CrazyJames View Postis ate super racing blue any good dannyf
I change from Blue to Gold when i do a change as its so easy to see new to old
one is blue
and one gold like std stuffthe truth is out there
part GSI part VXR
