hi guys by fitting the 1.9 airbox with k&n pannel filter does it sound any different inside the car. cheers. plus got a 1.9cdti already with k&n filter in it but its sitting in my vectra. what do i need to do to modify it to put it in my astra.
Yes, a cdti and a K & N would sound different, , I have only got a K & N and it sounds better anyway, . Is your cdti box from the vec? If yes, it won't fit, you need one from the astra, .
