dump valves
  • dump valves
    has n e one fitted a dump valve to there astra vxr and r they ne good and wat have you got...........................
    Use the search function, you will find loads of threads on the same subject.
    Here are some, but you will find more
    http://www.vxronline.co.uk/forum/sho...highlight=dump
      lds av innit, snd mint m8
        iv got a baileys DV26 and sounds mint mate, although recently i tried to upgrade to a DV take off hose and it sounded ****!! so i would stick to just using the fitting kit to use the normal bridging method... also it sounds louder once you have run it in for a few hundred miles. hope this helps mate!
          We have a Baileys DV26 on our Burg and it sounds awesome when your gunning it through the gears. It does get slightly annoying if your stop starting in traffic!
          A lot of haters will tell you not to bother as they cause running issues but its not true. We have had a DV on both our VXRs and not one problem.
          Chris.
            I have had them on other cars and they are great at first but after a while they just annoy the he'll out if you, as said stop and start but when going at speeds it does sound good ha, don't listen to the haters tho if you never had 1 you should try it, alot like them but not for me anymore. All down to personal taste
              Re-fitted my hks ssqv last night and omg i love it.
                If you do get bored of it you can always whip it off and put it on the shelf in the garage somewhere (or on the kitchen sink) as it only takes 5 minutes to take off/put on.
                Chris.
                  thanks all will update on decision....
                    I have the baileys dump-valve, its very good :-)
                    I also have a Pipercross Induction Kit and it sounds like a moose.
                    So in short, love the sound my VXR makes.
