Help!
  • Help!
    Hi
    Need a bit of urgent help. My car isn't very well. its smoking badly and not running right.
    How do i get it to show fault codes so i can check what it is? I've seen before there's a sequence of things to do then it will flash lights at you or something?
    Thanks in advance.
    if its smoking i dont think the fault codes will help you mate! sounds like a journey to the car hospital!
    i believe theres a how too thread mate
      I was thinking air sensor maybe, so if i got a fault code confirming it then I can stop panicking quite so much! ha.
        Originally posted by stretchVXR View Post
        Hi
        Thanks in advance.
        Sticky thread in the how to section - http://www.vxronline.co.uk/forum/showthread.php?t=33644
          Nice one, cheers
            Erm, i can't work out how to translate the codes, any help?
            They are, 10008, 10021 and 18007.
              There you go mate, not checked them do good luck. http://www.vxronline.co.uk/forum/showthread.php?t=33644
              Don't knock on Death's door. Ring the bell and runaway. Death really hates that.
                mybe turbo??? hope you sort it pal
