Need help, my car doesn't not start
  • Need help, my car doesn't not start
    Hello,
    Since 1 week my car doesn't start. My car is at the garage, but they are craps! 1 week, and they don't find the problem. Note that i have keyless.
    The symptoms:
    I can open/close the doors.
    I can put my light on/off
    The horn is ok
    The headunit doesn't work
    The CID doesn't work
    I can't turn ignition on
    I can't start my car
    Firstly, I think it was a fuse, but they said me every fuses are ok.
    And after that, i think that my problem come from the keyless unit or anything like that.
    I can not read error code because i can't turn on ignition
    Does anybody have had this problem before? or something like that?
    might sound silly but if your battery in your key fob has gone shorly it wudnt pick it up??? does it unlock n lock fine with remote?
      Yes it lock/unlock fine.
      I change the battery just to see, and used the 2nd remote and it's the same.
        if your car is keyless the key fob will automatically charge when the car is started, so will never run flat, i had dsomething similar happen to me it was due to my ecu,take it vauxhall
          is this mapped with a handheld unit?
            No it's happen a morning before i decide to go on my office.
            The car has been remapped a long time ago, but since a few months my car was standard.
            Replacing a new ECU will cost me a lot...my god!! i cross my fingers!
              oh, i forgot. Sometimes, the headunit works and the CIM too. But the ignition still off
                No it wont , the batteries are only rated for 24 months and is part of a second service to change them
                Originally posted by soosie
                  I had a similar problem, my battery had gone flat, but unlike your issue, nothing worked for me, couldnt turn on lights or anything.
                  Had to be jump started
                  Arden VXR / 17" TD 1.2's Gloss Black/Dreamscience RACE+/Forge Re-Circ Valve/DAP'R Springs/Quaife LSD/RARB/TX Tophat/3" BLUEFLAME/PIPERCROSS CONE Filter/Oil Restrictor Bolt/Courtenay CDTI Conv/Courtenay Engine Mount Insert/Black Rear Diffuser/Black Boot Strip/Black V-Grill/Black Fogs/Black Wing Mirrors/8K HID's/Wind Deflectors/Insignia Jets/Cruise/Auto Wiper and Lights/De-Badged/Anti-Hijack
                    I change the battery on both of the fogs. And nothing.
                    If it's my ECU, my headunit and my CID shouldn't work, isn't it?
                      think he meant the battery in the car
                        Sorry, it's not the battery on the car, we check it first
                          how was it remapped, by handheld unit?
                            Has the PEPS unit been tested as this controls the keyless start?
                            Has the actual start button been tested?
                            | Find | Watch | Follow |
                              My car is on the garage, and i hope they test the start button.
                              And the car has been remapped by the IPF and come back to standard a few month ago.
