cars just not right since being mapped :(
  • cars just not right since being mapped :(
    Well had car mapped in july,only for me to need a new actuator as the old one was knackered,so got a new o/e one fitted,but since then its just not really as responsive,low down it seems to just loose power then get it back,with sports on its obviously better as it is mapped but with sports off it feels really slow,an not just because im used to the map etc it really struggles to pick up,thing is its boosting ok,just is really unpredictable at the mo.Am pretty gutted as been saving for a while and spent about 1k in the past month
    any ideas if anything else could be worn/on its way out?
    cheers
    have you got a boost or afr gauge fitted? if so what readings?
    what map are you running?
    what stage you at?
    also did you re-dyno it after fitting the accuator?
    what fuel you using?
      what stage you at?
      got a boost gauge mate,its holding at 14psi peak 16 normal and holds 21psi peaks about 23psi with map
      its the eds 300bhp map
      stage 2
      always run on T99
        could be coz of the warmer weather.,
        did you have it re dyno'ed once you accuator fitted? may need tightening up abit more.
          yeah was 285bhp 350ftlb,on paper it seems fine,its weird an hard to explain to be honest
            a wideband would give more direction tbh
              Tom I'm sure it's something silly mate get it back up to MPG they'll sort it..
                hope you get it sorted mate
                  or loosening off a bit. how many threads are showing?
                    probs blown off a pipe
                      bout 10 ian
                        To be honest I wouldn't mess about too much as without a wideband etc its difficult to figure out how your car will be taking to your adjustments.
                        Best take it to MPG again as they can log the ignition / fuelling / boost and diagnose what is going on.
                        | Find | Watch | Follow |
