Buying a used VXR
  • Buying a used VXR
    Hi all,
    Great forum you have here, loads of information!
    I'm looking to buy a 2006 Astra VXR with 60,000 miles and I'm trying to find out if there are any faults, recalls or any particular areas of the car that I should pay extra attention to?
    I've done a search on the forum but I didn't quite get what I was looking for. Any help would be greatly appreciated!
    Cheers,
    Rob
    check gear box for wines and crunchs through the gears,
    the seats arent creeking,
    climate works if getting that.
    if got AFL check the lights move correctly.
    with the lights on check see if the horn works.
    check the tread on the tyres see if there evenly worn
    and give the tyres a kick lol
      i would check as beefy said plus look for smoke on cold start and when warm half of these cars get thrashed all the time !!!
      Astra vxr complete
      Full TMS rebuild Owens HTA k04
        Thanks for the help guys!
        Any other input is very welcome!
        Rob
          i would also check for blue smoke.. and that the turbocharger boost correctly...
          and if its had cambelt change
            check for error codes and have pen and paper at the ready to write the error codes down if any .
            heres a how to link >> http://www.vxronline.co.uk/forum/showthread.php?t=33644
            have at least a 30 minute test drive including motoway speeds .
            check oil return pipe for leaks ,
            drive with window down and listen for anything that doesn`t sound right specially when changing gear .
            if i was buying a 2nd hand vxr i`de also be checking plugs / filters / seals / manifold / exhaust ect...
            make sure all tyres are evenly worn with plenty of tread on them .
            have a good look for stone chips / scrapes / scratches ect ,
            make a list of all known faults that you`ve seen and are aware of and then knock the price down
            on collection day allow extra cash to give it a full tank of 99ron fuel and enjoy
              check if its got petrol!! you will be needing plenty
