Astra VXR - Hub Speed Sensor
  • Astra VXR - Hub Speed Sensor
    Hi All!
    Fault showing up with ABS, IDS and ESP warning lights. Been diagnosed as a faulty NSF speed sensor.
    Anybody know if the entire hub needs changing, or if there's a history of faults on the wiring for the sensor? Also, any ideas for places to get the parts cheaply would be welcomed!!!!
    Phil
    ive not heard of any wiring faults mate dont think its common, unfortunatly it is a replacement hub if the sensor requires replacing
    mite be worth taking the wheel off and checking connections first if you havent already
      this went on my mk4 turbo mate, speedo was all over the shop to because of it. abs and traction control also off!!
      unfortunately i had to replace the whole hub i think from memory
        its a sealed unit.
        I think my VXR had it replaced buy the previous owner. A hub from vauxhall will be 200+
        if you goto a motor factors they should sel you an SKF one fr about half the cost
          Thanks all for the info, greatly appreciated!!
