question about dream sciense
  • question about dream sciense
    im buyin a d/s of a fourm member but they have not got the cd disk or the cable for the pc?? as i know nothing about the dream science i need help on this is it pointless me buyin iy or can i still use it??
    i dont have a cd or pc wire for mines either, its just plug and play into the port under your handbrake,
    what would you need a cd or pc wire for?
      no i dear its just wot she told me but thanks for ur reply m8
        Dont worry about the disc or the pc cable you wont need it. The only thing you need to make sure, is that the handset matches your type of ECU or it will have to be sent back to be re-programmed.
        If your car is newer than 56 plate, make sure the handset has also been used with a similar car.
        There are 2 types of ECU, pre and post 56 plate.
          no problem m8, your guna love it, especially with your remus, only think to look out for is what reg of car you are buying from, as the newer 1s only work from 07 plates to newer, if the seller is older than 07 it wont work without a reset
            darn it dab you beat me too it
              I found out the hard way, mines a 56 and thats the point they changed the ECU. And yep you guessed it they sent me the wrong one
                she has a arden m8 nd i have a burg so am ryt in sayin its all gud then??
                  yes but what year is her arden? 2007 plate and newer and you are good to go
                    im just waitin on a reply
                      just found out tht the cable aint for the pc it for the actual unit so i need a cable great bk 2 sq 1
                      and just had an interesting PM off a few ppl aswell lol tell me sum story's about the seller !!! not happy
                        ack well no luck, back on to the search trail
                          its a 57 plate it will be fine
                          Stage 3 Arden Astra gone
                          Stage 2 burg
                            Impossible. The cable that runs from the handset to the car is permenantly attached.
                              unless some one got mad with it lol, mate its fine
                              Stage 2 burg
