whats the best oil
  • whats the best oil
    i have just been to a local garage and they have said the best for your type of oil for my car is
    AC Delco 5w30 fully synthetic ??
    as i have just had my D/S fitted i want to change the oil and filter and everything but wanna make sure its the right oil i put in, i will fully drain the engine then use this if any1 else is using this or if they think its fine ??
    There are two main requirements here;
    1. Ensuring that you maintain the car to VX standards with the use of oils and parts for your warranty to stay in tact. Any 5w30 or 0w40 oils confirming or bettering the GM min standard for oils is acceptable, and will be fine for a std VXR.
    2. If you really want to care for your car put some better stuff in !
    To do this contact Oilman on here and ask him what to use but the cost will go up !
    I would think he may point you towards specialist Miller and Silkolene Oils fully synthetic or Ester Oils.
    For more info on Oils , try and search on here for posts by OILMAN
    hth
      hth
      cheers bud
        cheers bud
        No worries
        Infact ive just seen his latest post;
        http://www.vxronline.co.uk/forum/sho...d.php?t=102964
          just ordered my silkolene pro s 5w 40 from opie oils. there's a deal on it atm
            0w40 Mobil mate thats what mine has had in it since it was born!
              Why the 5 40 mate? Interested to know?
                for my state of tune i want a thicker oil than 30
                  I think he was more after an explanation why you use 5w40 as apposed to 0w40 like he uses
                    To all the Costco members they are now doing the 5L size instead of the 4L and it's £28ish from memory
                    Astra
                      http://www.opieoils.co.uk/p-68897-fu...ngine-oil.aspx
                      silkolene do not do 0w40.... i use the above. atm i have 0w40 mobil in my engine and have noticed that it stays clearer a lot longer than silkolene so i'm thinking it may not be cleaning as well, i maybe wrong. personally i would prefer the greater cost of more regular oil changes to look after my engine. i'm no oil expert so have taken oilmans advice.
                        When we going
                          silkolene do not do 0w40.... i use the above. atm i have 0w40 mobil in my engine and have noticed that it stays clearer a lot longer than silkolene so i'm thinking it may not be cleaning aswell, i maybe wrong. personally i would prefer the greater cost of more regular oil changes to look after my engine. i'm no oil expert so have taken oilmans advice.
                          Hes a salesman mate hes going to advise his products over mobil.
                          Oil doesnt clean it protects
                          I think Regalvxr (darren) uses silkolene so i wonder what he thinks of it?
                          Only reason i asked mate was ive seen and read guys putting in 5w35 but not seen the 5w40.
                          ive asked Oilman for advice before but his advise wasnt very specific...
                            he sells both. go to opie oils website there's enough info there
                              Haha thats what Oilmans reply was almost
