break squealing
  • break squealing
    everytime i break im getting alot of brake squealing. is this normal on the astra vxr?
    Arden Astra VXR
    Black e92 320d
    Silver e92 335d
    Blue e92 m3 dct competition pack
    Mineral white m235i manual
    are the pads on their way out?
    Tech2 Diagnostics
      mine started to do for a couple of day's never done it befor had it .. over a year but now has stoped
      i think it must be somthing just geting inbetween the disc's and pads.. will go away
        New pads and disks in february, only done a few k since. been like this since new.
        Arden Astra VXR
        Black e92 320d
        Silver e92 335d
          check the backing plates at the rear of the disc arn't touching the disc, if they are shove a screwdriver in and make a gap of around 10mm. Stops squeaking instantly. Though vxr brakes tend to squeak a lil anyway when they get hot. I don't no the reasons for this.
          Rest-In-Peace 'James Tierney' 18.9.1991 - 16.10.2010
          Rest-In-Paradise Angel, 'Kirsty Malin' 5.12.1990 - 21.8.2010
          "Out The Way 4|2 Commando RM Taliban Hunter VXR Coming Through"
            also check the pads have a chamfer on the leading edge. as a flat edge can cause a squeek. if it doesnt make one with a file.
              This used happen years back and what people and garages used to do was put copper slip on the back of the pads [the side's that touch the piston's] this will help to stop them squealling.
              If I remember correctly the small gap around the pads and the pressure of the piston
              when braking makes the pads chatter which gives you the sqealing sound.
              Or it could be as already suggested you need to change the pads again ?
              Best have a look at them and then you will have a better idea.
              Good luck
              Would like to do more,
