found cheap(er) o2/lambda sensors
  • found cheap(er) o2/lambda sensors
    http://www.eurocarparts.com/ecp/c/Va...e3c19dcba&LAMS
    found these, cheapest at the moment
    nice find
      Originally posted by sandyVXR View Post
      nice find
      yea i like to shop about abit. like to find cheaper everytime i buy something.
        Good find still not cheap though!! They never are!
        Astra coupe: z20leh with m32, eds 3.5, remus, dbilas induction and inlet, berg trim, corsa vxr steering wheel and a whole lot more!
        www.asautocare.co.uk eds retailer.
          need to make this a sticky
            if its a genuine product then yer i agree
              how do i do that then? if a sensor for a metro gti cost me 28 quid from a dealer then how come these are so expensive?
                it is genuine as Vauxhall use a Bosch fuel injection system
                  Just a quick one, Are our o2 lamba sensor a wideband sensor?
                    iirc it will give figures as narrow band reading, as ive read before on there sites that you can connect wires from your gauge to the front o2 sencers to take the readings.
                    narrow bands arnt as accurate as wideband.
                      You knew wat I was thinking then lol,
                      Looks like a complete kit it is then, I assume i can get a boss or wat eva welded into the replaced precat section or will anywhere before the cat be fine?
                        what exhaust you got?
                        ive got mine mounted in the exhaust just behind the engine so that the probe is well protected an cant get damaged. wouldnt mount it to close to the turbo as the probe are quite sencative.
                          Piper
                          So somewhere after the precat section but before the cat and out the way pretty much.
                            yeah mate, also with having it behine the engine an pointing up, its direct access and an easy route for the wires.
                            which gauge you going for mate?
                              Dunno yet to be honest mate, Need another gauge holder now I got the 3 gauge coming that my defi gauges are going. Which reminds me, I still want your one when you come to sell it lol
                              Fancy summit digital with the led ring representing lean/rich. Any suggestions? What one do you have?
                              Ill check and see if defi do a afr gauge, would match my others then,
