cool running thermostat???
  • cool running thermostat???
    anyone got one? and what difference does it make and is it worth it??? cheers.
    A few people have them,
    It allows water thru to the radiator at a lower temperature (approx 10 degrees) where it can get cooled by your car moving. It will keep the temperature of the water lower, except when you car is stationary as they is no air flow to cool the water.
    Another benefit is that your fan should not come on that often, as this is programmed to come on at a certain temperature.
      Originally posted by vr55vxr View Post
      I few people have them,
      would you say its a worthwhile purchase???
        I have one in mine and never had any real temp issues out on the track, even in the australian summer.
          i was thinking on getting this too
            iv been thinking of getting one but was told where they open early the car struggles to get to temp in the winter is this true?
            courts stage 3 297bhp 343ft/lbs
            vxr gone onwards an upwards
              think I need one my car is always in the 90s
                i have one on my car and it warms up sooner than orig unit
                  Again another mods which is cheap and will help keep temps down for the money may aswell
                  I have onesee my sig
                    got one would reccommend one,anything that reduces engine fatigue is a winner in my book
                      great i got one, bargin too. helps keep temps down.
                        No lol
                        courtenays now do 2 cool stats with my air con removed my car runs at 80 so now getting the slighty hotter one.
                          Anyone had any problems with these? had one fitted on my other car and ruined performance as was opening before engine got to optimum operating temperature.
                          Russ
                            I'll answer with a question if I may.....
                            Have you monitored your current temperatures ?
                              had no problem with mine had it fitted for about 1 year
