oil return pipe
  • oil return pipe
    just went out to have a look at the car as on way home last night i heared the turkey sound
    i found were the sound was comming from Rec valve well i sounded closer to the front and the pipes at the back seemed ok but found oil on the outside of the return pipe any idea's why this may be? was like condensation
    435bhp 410ftlb astra J VXR
    RSS induction, RSS Fully Forged, 3" turbo back, Forge FMIC, EFR6758, Nortech Mani, Proalloy water rad, 2way KW Clubsports, Forge brace, 1/2 Roll cage, Recaro Pole Posistion, Forge braied lines, AP Racing 362mm & Pagid RS29, lightend fly & uprated clutch
    Oil will leach through your front right breather pipe if that's the one you mean?
      I think he's talking about the turbo oil return pipe just behind the heatshield (back of turbo).
      I think these often leak, check the bolt holding the pipe in place.
      If your getting the turkey noise its a loose boost pipe near the rear of the engine iirc. Search for threads on here which will help to diagnose.
