Forge Recirc Valve Help!!!
  • Forge Recirc Valve Help!!!
    Hi guys
    I'm running standard map with a scorpion exhaust (turbo back) and thinking of buying a forge recirc valve.
    Just wondering which springI would need to fit? Am I right in thinking that the standard spring (green) would be sufficient or would I be better upgrading to the yellow spring?? If I upgraded to yellow would it still perform to it's best or would there be no point??
    Sorry for the questions
    Arden Blue Astra VXR '57' private plate, 19's, Keyless, AFL Xenons+leds, Sight&Light, Alpine W502 Double-din headunit, Percy's oil restrictor bolt, PPP , Opel grill, Scorpion 3" , Forge recirc valve, Eibach Sportlines, Whiteline adjustable rarb, Custom Intercooler, Colour-coded fog rings, White Carbon Fibre roof, grill & boot strip.
    Green - fo sho mo fo!!
      dont rule out regals one mate,ive got it fitted in mine,no springs to worry about,it uses a piston,ive seen both this and the forge and the regal one seems much better quality IMO
      Holds boost alot better,your welcome to have a go in mine to see what i mean if you want
        They both use a spring - it's what holds the piston (which they both have) closed against the pressure of the boost. I personally think the inclusion of a second spring for higher boost applications with the forge makes it a better bet than the regal one, but that's what makes the market so good - choice!!
        To be honest I've never seen the Regal one close up but I can't see it being £50 better for something that does exactly the same job.
          your right there is a spring,my bad forgot about it theres a thread on here somewhere that explains the inner workings of both more in depth will try and find it
            I've ordered mine today. The guy from forge said because of the level of tune he will send out a yellow and blue spring.
              I have the forged one and i've drove mine back on the stock map with yellow spring in and the car was fine it was not stalling the turbo or anything. but if you staying standard i would fit the green its not hard to change them round at a later date theo.
                you will need charls hands to fit the thing though must have cut mine all over fitting mine lol
                  I've the forge item fitted to mine too, excellent build quality.
                  | Find | Watch | Follow |
                    lol i was the same and with alot of #@%#
                      If your planning on remaps etc then you might aswell put the yellow one in now.. saves you the time later on
                        i got the yellow on mine and running on dreamscience remap
                        Arden Racing Edition
                          Guys, so, if I am running stage 2, I should use the yellow spring then? Cheers.
                            yes.
                            i didnt notice and difference when changing the valve
                              Cheers guys for all your help (as always) ordered a forge one this morning with the green and yellow springs. Just got to wait for it to arrive now
