boost control solenoid???
  • boost control solenoid???
    Thinkin of makin the uprated boost control solenoid my next purchase when i get paid in a couple of weeks. Haven't heard anything about them on here, so was just wonderin if anyone has got one fitted and whether its a worthwhile buy? Am thinkin it will be good with my remap as it will maintain boost for longer. Also, are they easy to fit? Cheers
    you have one fitted as standard
      LOL!!!
      To the OP, do you mean an adjustable boost controller or did you mean what you wrote?
        Probably better investing in other things your standard exhaust won't be able to shovel heat away quick enough. If you hold boost better i.e. higher figures temps will increase.
        I think he means adjustable boost controller or actuator perhaps.
        | Find | Watch | Follow |
          i'm referring to the uprated one, from regal. anyone got one???
            The OP perhaps means the uprated one as sold by Regal on their website. It looks very similar (if not identical) to the N75 valve fitted to Audi/VW/Seat/Skoda etc.
            http://www.regal-shop.co.uk/vauxhall..._Upgrades.html
            Bottom of page.
            EDIT Beat me to it . I've got one, but not fitted it yet.
              Apologies dude, this won't up the level of boost you run and you probably won't notice a difference to be honest unless yours is failing. A worth while investment if your OEM does fail.
                Bottom of page.
                Ahhh yes, looks like a waste of money - the standard one works fine and i highly doubt that air leaks past the base as per their description. However on high stage cars i guess this could be possible.
                OP - a better bet would be to get the Forge/Regal actuator which will gie you a more noticable effect.
                  cheers buddy, appreciate some non p1ss takin advice lol
                    No worries dude, your logical next step is a turbo back exhaust. Plenty of second hand ones on here now.
                    Even a 2.5" system would do the trick and some can be had for as little as 400 quid.
                      Haha you wont find much of that on here m8
                        Think he is refering to the 3bar version.
                        AFAIK, you cant just fit this as a replacement - you have to change your map etc
                          tell me about it, one mistake you all pounce like vultures! i should be more careful.
                            ahh, guess this puts an end to that then.
                              where is the actuator on the site???
