T/C off= pops and bangs off
  • T/C off= pops and bangs off
    A few times recently i have driven with the traction contol off (hold sport button longer) to see what effects it would have regarding responsiveness.
    What i found is that with sport button off (not pressed) there are considerably more pops and bangs from the exhaust when giving it some beans, however if pressed to T/C off there are less pops and bangs, is this normal ?
    I find i get more with the sport button on lol
      TC off would be the same as sport on (throttle wise) so is it the same just sport on with TC still activated?
      Astra
        My findings are if i have T/C off (light on dials) i get less pops than i do with just sport on or leaving it unpressed.
        At first i thought it was me, so ive tried it several times to compare and get the same results
          yes you will do
          how hard are you driving and getting a bit of wheel spin ??
          the truth is out there
          part GSI part VXR
            Originally posted by dannyf View Post
            yes you will do
            About the same throttle as i would use standard to achieve pops,so its wheel spin (not felt any) reduces pops ?
              When u wheel spin or struggle for grip it would normally cause t/c to cut ignition meaning unburnt fuel would enter exhaust (I think)
              Stage 3 Arden Astra gone
              Stage 2 burg
                That's what i'd put my money on too
                  But i get the reverse !
                  T/C off = less pops
                    Yep, that's what was meant. With traction on you will get the ignition cut if the wheel slips, even slightly meaning all the fuel that would have been burnt goes into the exhaust giving you the pop. Without traction on, the wheels just spin meaning the engine is using the fuel itself, if that makes sense?
                      correct.
                      i get same too.
                        yes thats it
                        part GSI part VXR
                          I was giving mine some with the TC off which I don't do very often last night and I noticed this. I also noticed the car is an absolute animal with it off. Pulls much stronger with no crappy delays.
                            lol
                              I agree with this too mate .... also the TC is far too sensitive, it just cuts in far too early TBH . Coming off roundabouts here in Aberdeen, especially the inverurie road, as its a 70MPH limit, in 2nd gear and giving it the beans as soon as 1 wheel slips slightly in cuts the TC and shuts down the fun Sometimes it feels like there a prob with the car not boosting right. but if you turn it off and do the same it just pulls hard with no probs and you feel no wheelspin at all.
                              Rant about Vauxhalls rubbish TC over !!!
                              James
