Boost drops out on full throttle. Any ideas !!!
  • Boost drops out on full throttle. Any ideas !!!
    Hi guys just need to know. When I put full throttle on when accerlerating It sometimes drops off boot then back on. It's as If the traction control is kickin in. I have tryed turning my traction control off to and it still does it but not all the time but it does run fine when driving normal. Any ideas's
    what map you running? age of car? miles??
      standard map sounds pretty normal as get flat spots
        I'm running the regal nerbergring map phase 1 but the car did do it on the standard map. Car is a 2007 and has done 22000miles
          Is it as bad on that map as it was standard? As beefy said, the stock map does it. Mine didn't go away until i changed the induction.
            It's not that bad but its the same aa standard. Could it be the plugs or something like that
              It's possible, but it could just be the map. Have you tried any of the other phase 1 maps to see if it does the same?
                This is my secound phase 1 map I've tryed. I hav got a k&n filter too. I'll try some other though
                  cone filter?? if you not got a good enough cold air feed and heat shield you could be heating heat soak which wont help.
                  you have low miles so i very much doubt it would be you actuator going weak.
                  the warm air atm will make the car feel bit more sluggish too.
                    my dads coupe did this turned out to be afm
                      if it really drops off like said could also be the sparks.
                      not got aftermarket ones have you?
                      stick to standard plugs. might be worth changing them now you done 22,000 miles. espeally with a map on.
                      i had some aftermarket ones gap wasnt right so on boost played up sometimes regapped them and ran great but changed them after 15k. didnt want tips dropping off
                      if you have got a cone filter worth looking at that too
                        tms, said to me too a i contacted them about me bein para. they said dont trust boost gauge dont give accurate reading. as it still goes fast they like dont worry.
                        if it bad get it checked out and it could be potentail AFM or weak actuator
                          mmm boost gauge not acurate lol they real lol.....
                          tech 2 picks it up easy enough hey col
                            yeah i know lol.
                            yeah it should do mate. worth if you think that bad seeing if you could find out what boost its running at see if it drops off or anything.
                            but deffo sort cone filter (if that what you got) and plugs id look at.
                              Ok I'm not running a cone filter got a k&n panel filter. I'll try and get some new plugs then. Would u say iridium ones r ok and also do u think it's worth tech 2 to c if anything flags up
