which spark pugs for 330 bhp plus
  • which spark pugs for 330 bhp plus
    as above as i am going to be running a gt2876 soon and will be bout 330 bhp cheers tom
    Percy runs std plugs on his Garret - they can cope
    Astra
      standard plugs, will just have to replace them more often
        whats poing of having a 2876 an only running it at 330? wouldnt you be better running with a 2871?
          becoz for now only runing 330 then when i have done interinal etc i can be 400 easy plus got for a gd price
            so just got for standard plugs cheers any one know the part numbers?
              Just my recommendation, *dont shoot lol* personally if I was going to be running much higher power of invest in the NGK7438-8 race spec plugs mate,
                was thinking of the ik20 densons irdiums
                  i ran them at st2, weren't very good for st3 now i use iq24
                    PM mattbibs - he'll give you a posted price
                    Astra
                      Cause percy knows what hes doing lol. He runs very very low boost
                      Clique #14
                        He wasn't questioning Percy
                        Astra
                          where do u get the NGK7438-8 race spec plugs from and how much?
                          the ik20 no gd then?
                            stock VXR plugs used to be NGK PFR6T-10G,but they are now NGK PFR6T-G.gm part number is 55562534 if you want some.
                            the 6 temp range is about right,cooler running plugs are actually for hotter running engines (higher charge temps).with the bigger,more efficient turbos,they put much less heat into the charge,so if you run a cooler running plug aswell,it wont get hot enough to burn off any excess fuel/clean the tip,and you risk fouling them.
                            how come you went for the 2876 and not the 3071?,even garret themselves are a bit iffy about them?.
                            http://www.turbobygarrett.com/turbob...R_705330_1.htm
                            ...superior horsepower through knowledge,good design and maximum efficiency
                              i asked same question as the 71 would be well able to do the job..
                              his reply.
