how much oil and coolant needed?
  • how much oil and coolant needed?
    Morning all
    ive tried a search but cant find the answer in the first 7 pages so quicker to ask...
    Exactly how much oil and coolant is required when servicing these areas?
    Chris
    oil 5 liltres
    coolant never really replaced on tiny bit when doing cool thermostat. just topped up with liltre coolant and rest with water. if you over fill it will go throught over flow pipe
      im getting water pump done so the system will empty....
      Just need to know how much to order so i can refill the whole system and not be left short!
      Thanks for the reply mate
        you need a coolent tester to be honest. dont think many people no exact amount the coolent system can take im unsure. you can buy coolent from anywhere. cheap.
        rough quide 30% coolant and 70% water -18 deg.
        50% coolant and 50% water -34 deg. me id try go about 40% / 60%
        like said unsure how many liltres system takes. sorry
          hynes manual?
            If I just order 2 litres it should be fine
              put the two lil in. then top up with water.
                cheers buddy i think i will do just that.
                  Recently done mine, its about 3.5 - 4Litres. Plus if your getting concentrate you should mix with water before putting it in really rather than letting the car mix it for you. :-)
                    coolant system is about 7.7 litres from a dry fill.i.ve drained mine a few times and get about 6-7 litres out.the coolant does actually go off over time,so it is worth changing every couple of years for some fresh stuff.
                    factory mix is 44% glycol,but i do find the better mix is 30% with a bottle of water wetter in.
                    oil is about 5.25 litres with a filter change.if you can,ask for a VOF93 filter over the white mahle item as they only go on about 2 threads before going tight.the VOF93's are a much better fit.
                    ...superior horsepower through knowledge,good design and maximum efficiency
