Keyless entry/start
  • Keyless entry/start
    Right i've got my vxr booked in tomorrow to have the keyless entry checked out, basically what happens is the car refuses to pick up the key fob and so either refuses to start/stop the engine or at times lock/unlock in the first place. The bloke i spoke to at the garage said its a fairly common fault, so has anyone on here had it sorted and could they give me a rough idea what the garage is likely to say.
    Cheers.
    May be a simple issue, the battery requires changing in the key fob.
      Key fob
      Does it do it with the spare ?
        Yup, does it with both keys and the battery was changed on one when it went in for the service last month.
          Key fob
          In that case its a job for the garage, good luck.
            could also be the sim. Mine played up a few times, I use to lock and unlock with the fob then it would be fine and start ok..
              Ah that might be it, was sat there the other day for 5 minutes holding the key underneath the sensor and it wouldn't let me turn the engine off
