errors: P0141 P0135 P0130 P0443
  • errors: P0141 P0135 P0130 P0443
    Hello guys
    I have some fault codes with my vxr.
    Someone can help me please?
    Total number of fault codes: 9
    P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) (0D) - Present
    P0141 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2) (02) - Not present
    P0141 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 2) (04) - Present
    P0135 - O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)(0D) - Present
    P0135 - O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 1)(02) - Not present
    P0135 - O2 Sensor Heater Circuit Open (Bank 1 Sensor 1)(04) - Present
    P0130 - O2 Sensor Circuit Range/Performance (Bank 1 Sensor 1)(04) - Present
    P0443 - Fuel Tank Ventilation Valve Voltage Low(02) - Not present
    P0443 - Fuel Tank Ventilation Open Circuit(04) - Present
    P0443:
    A: i must change this?
    P0141 P0135 P0130: lambda sensors 1 and 2, to change too?
    thanks for your help
    astra opc silver lightning 300+ . cdti airbox . cobra exhaust 76mm. forge Intercooler . forge recirculation dump valve .Walbro fuel pump . dbilas aac . klasen intake manifold . klasen stage 4 . soon: forged internal . big turbo -> 400+
    up!
    P0141 P0135 P0130 : must change 2 lambda sensors? :s
    for P0443 i order a new "Fuel Tank Ventilation "
    anyone can help me?
      wow thats strange i have the same problem and wa sjust about to ask the same question
      i changed my front lamba but no diffrent
        I have the same codes, that have popped up on my burg, how did you sort this??
        I have changed both lambda probes!
        Ben
        Nurburgring Edition No. 646 Scuderia Red Wheels Regal Stage 3 310BHP/356FT Tourque
          My guess would be the lambda and tank vent share either a power feed wire or fuse which has failed.
            Yes as there genuine lambda's, also was thinking the same thing! and where would i find the fuses for them?? Im new at this game.
            Ben
              I think its fuse 26 in the under bonnet fuse box, look in the handbook for the location of the fuse.
                After taking the inner wheel arch out and getting to the tank breather box, that was all okay, and no splits in pipes, i check the fuses ans it was a 10amp fuse that has blown, not sure what this was due to but will have to look further into it, thank you for your help.
                Ben
