help please
  • help please
    hi i got a nurburgring engine light keeps comeing on been turned of bout 8 times had it remaped by sum cowboy got worse so took it 2 thorny motorsport got put bk standerd new itg filter plugs got it nice then stage 2 map bluefin put on it light came bk on looseing boost now after 4 grand goes flat not sure wat 2 do if any1 can help b gr8.help
    Welcome to VXROnline,
    Do the pedal test to get the error codes - http://www.vxronline.co.uk/forum/showthread.php?t=33644 and post the codes.
    Sounds like a loose pipe, check all the pipes do not miss the ones at the back of the engine.
      ive give up
      been bk 2 thorny again changed a 02 sensor 200 miles came bk on code po420 ive cheaked all hoses every thing. could it b the remus exaust or the sports cat. thank you
