Boost figures for EDS IPF 315 map?
  • Boost figures for EDS IPF 315 map?
    Hi, running the EDS IPF 315 map, overboosting 1,5 bar, holding 1,0 bar from 5400 rpm and up, it seem a little low compared to what i have read in other treads.
    Please post your figures with this map.
    Thinking of adjusting the actuator, but i have been told its the ecu that controls the boost!
    yep
      22psi overboost holding 18psi but does drop off right up the top end down to around 15. So without seeing your boost graph, it looks about right if you are running a standard actuator
