Dash rattle!
  • Dash rattle!
    Hello all,
    I have a rattle in my dash friom the clock cluster area. It goes when I press down on the dash above the clocks.
    Its at about 2500 rpm when cruising or when reving when standstill.
    Anybody else got this and found a way to cure it?
    Vauxhall said it wasnt covered under warranty!
    Dan
    12 plate Astra GTC SRi cdti 165 stop/start in white.
    Anyone?
    I'm starting to punch the dash now! Lol
      feel for you mate lol
        It's just appeared overnight! Lol
          strange lol turn ya music up a little more
            That's what I'm doing! Lol
              did you ever fix this? similar thing happening to mine :z
              Astra VXR Nurburgring Edition #270
                No mate, still there along with a rattle from passenger door panel, glove box and the interior light cluster and the roof lining!!!!
                I've given up lol
                  Oh and a ticking noise from the drivers side seat belt! Lol
                    The rattle with the clocks is a known fault and there is a part that needs fitting (two foam strips) to sort it:
                    Originally posted by TIS2000
                    Field Remedy: 2451
                    Subject: Instrument panel (IPC) - Creaking noise
                    Models: Engines: Option:
                    Astra-H 2004... All
                    Complaint: Noise coming out of the area of the IPC between 12-13 degrees ambient temperature.
                    Cause: The noise occurred between the IPC and the dashboard. The noise disappeares if the IPC is pushed to the dashboard.
                    Production:
                    Remedy:
                    In case of customer complaint remove the IPC and install two addtional
                    foam strips part-no.: 24417127 / catalogue-no.: 11 90 370
                    (picture I, 2) on both instrument panel fixing points (picture I, 1).
                    Note: Grease the foam strips after installation with silicon grease
                    part-no.: 90510259 / catalogue-no.: 19 48 605.
                    SMD conversions, cruise control, speed dependent locking/anti-hijack, check control programming, diagnostics, software updates - based in West Yorkshire
                    Radios and displays decoded/divorced without the code
                    Genuine Vetronix Tech2 with SPS and ******** used - no Chinese clone stuff here
                      Was this a recall mate?
                        http://www.vxronline.co.uk/forum/sho...+rattle&page=3
                        Trist seems to have had a similar problem to yours (and mine!) but hasnt found a solution either. Mine is exactly the same, if you go over a bump or if the car vibrates for any reason, and especially around 2000RPM the clocks rattle like a mofo. If I press down on them it stops straight away hehe. I read on here someone took it to VX for the same problem and they glued something which stopped it. Might try that tbh :/ bit of superglue to hold it down a bit more would solve it probably. Only seems to happen when its cold I think :S So maybe the plaster expanding/shrinking with the temperature. It totally disapeared for a good week or so but has just come back with vengeance
                          Totally didnt know this! VX didnt seem to know when I took it to them either, will print this off and take it down tomorrow! cheers for the info mate
                            Nah, not a recall, it's a field remedy. It's not a safety issue so it's just done as and when people complain about it.
                              Ill be complaining tomoz
                              Any idea on my other rattles!
