more power from uprated fuel pump and actuator???
  • more power from uprated fuel pump and actuator???
    Are there any power gains from fitting an uprated fuel pump and uprated actuator????? cheers.
    fuel pump no, an no with the accuator. it will just aid in holding the boost better
      whats the benefit of the uprated fuel pump then? and what price are uprated actuators generally???
        when running higher power over stage 3 the oe fuel pump begins to struggle as you have to push it harder to cope. so gitting a larger pump gives it an easier time if you get what i mean...
        as you are running stage 1, you dont need it mate. id spend your money else where.
        all depends which accuator you use, the forge one is about 150 quid IIRC
          cheers buddy. One last question, are the actuators easy to fit???
            yeah, as long as you have the right spring in. best to get it on a dyno to check that it all set up right.
              spring? this is goin into unknown territory now for me.
                with the forge accuator, you can change spring pressures which helps keeping the gate closed at differant levels of tuning stages.
                eg,
                red spring - stage one
                green spring - stage two
                white spring - stage three
                note, the above is just an example and the colours maybe differant
                  eg,
                  so as you tune up you'd have to change the spring at the varying stages?
                    yeah mate.
                      yeah mate.
                      are the springs easy to change? and what price are the springs?
                        think its just a mater of undoing a few bolts, removing the lid and swapping the sring out, now thats what i have to do with mine but mines not a forge one so i cant be 100% sure as i havent used a forge one.
                        have a look on foges website for prices as im not sure.
                          they're about 150 quid inc vat.
                            theres a group buy on at the mo for them 125 quid delivered but it ends in like 2 days. springs are very easy to swap 6 allen bolts. and stage 3 is yellow spring sandy thy dont do a white 1 i dont think
