7500rpm
  • 7500rpm
    does any1 elses rev up to 7500rpm after there re-map
    EDS maps will, I don't think Superchips will.
    Clique #14
      Yep the superchips maps do not rev as high, must be some good quality rods and bolts in these as standard to rev up to 7500.
      | Find | Watch | Follow |
        why would you want to rev up that high as the turbo isnt working aswel for your car at those rpms, and is most probably causing damage to the car????
          I have stage 2 map from them with Regal Inlet cam and car pulls all the way to 7500rpm
            It all depends on your power band.
            My gt28 runs out of legs at the top end of the rev range so my limiter is set to 7250rpm.
            When i get the inlet manifold it will allow the power to be held alot longer so the limiter will be set to 7500rpm.
            The best thing to do is look at your rolloing road graphs and see if it is actually worth raising them to 7500.
              yes but how hard are you working the turbo? as after all isnt 7500rpm garret turbo territory and not standard turbo stuff?
                yep so if you are stage 2 on a standard turbo doing these rpms then the turbo is doing nowt as you are out of its power band
                  Looking at EDS graphs its still holding 1.1 bar boost up that high. The torque drops but from 4000rpm to 7500rpm the power is a constant.
                  Clique #14
                    can you post the graph up please?
                      EDS wouldn't raise the limit without good reason, they must be confident it can still make power safely at these higher rpms.
                        Not got one personally I can put up but seen a few stage 2/3 graphs.
                        Clique #14
                          You can't just look at the engine torque curve in isolation, you have to take into account the gearing and final drive. Most of the tuners will raise the rev limit because even if the engine torque is dropping away the gear ratios are spaced such that you still have more torque at the wheels than if you changed up a gear.
                          I don't have a graph for the vxr handy but here's one i was working on over the weekend for a friend of a friends supercharged honda race car.
                          You can clearly see that in the first 3 gears there's more torque at the wheels hanging on to the lower gear even though the torque at the crankshaft is severely falling away. result = faster acceleration
