any one running cone filters..???
  • any one running cone filters..???
    had one b4 and was rubbish.. but am fanceyin a change from the cdti set up for a while..
    so whos running them and do you have cold air feeds to them?? show me pictures if you have any..
    surely these cant be as good as the cdti setup? why change a winning formula.
      You'll need to enclose it in some fashion to protect from heatsoak. I don't think you'll better the CDTI setup.
      I am happy with the standard setup and can easily handle well over 300bhp.
      | Find | Watch | Follow |
        like the cone noise alot, i had cone on but it was old so i lost loaaaddds of power but i think a brand new cone filter will go a little better..
        the noise is like a dump valve noise but alooottttttt louder swoooshhhhh
        http://www.youtube.com/watch?v=1s9v6KYQLjM identical to this..
        and yes i no its chattering which is what i like
          Look at a BMC or a Viper if you are looking noise
            mm am interested now, they go for alot of money?? ill be keeping the cdti still but for a couple of month i will run cone and then cdti etc.. just for a change
              am not keen on all this stuff, i'd rather just spend the money on stuff that makes it handle better and go faster. the only noise i'm keen on making is a nice exhaust note lol
                both are close to £200
                  with the amount of under bonnet heat the astra produces a cone filter would imo seriouslly hamper performance.
                    wud it be ok if i put a k&n cone filter in my cdti hose?? as that what i did last time, the cone was old so i lost power but if i get a new one will it be ok in the hose?? obiously all tight in not just shuved in etc..
                      As said above due to the amount of heat under the bonnet fitting even a brand new cone filter would loose power as once warm the car would such soley hot air especially if fitting in to the cdti hose and hen there would be no cool air feed .
                      obv i have not tested this but would bet it would loose power .
                      intake temp would be sky high
                        As long as it slots onto the neck of the pipe then yeah you could use it. You could also use a reducer to make it fit.
                        You will loose performance especially on hot days, on the move it won't be as noticeable as long as you get a good feed of air up into the filter.
                          mm i dont know now, as when i had one ast time, it was shocking but i thought a new one might be ok you see.. just want sum engine noise n miss that noise lol
                            MTECH offer a cone option.
                            http://www.mathijssentechnics.nl/?Vi...&lvid=&mid=123
                            You could do something similar and test to see if you are happy.
                              dont bother buddy if you ask me. you dont wanna hamper your cars performance.
