Few questions Re.exhaust manifold
  • Few questions Re.exhaust manifold
    How do i know if my vxr has had the manifold studs swapped? As i heard about a fault with them?
    Is miltek vauxhall approved? If i fit remus/miltek can vaux tell it wasn't factory fitted?
    Also when i rev my car about 5000rpm sounds a bit tinny, cant find any loose baffles, the heat shield isn't loose. Only does it high up revs.
    Any idea's?
    Any info is appreciated. Thank you.
    All the aftermarket exhausts are not fitted by the factory, this includes the remus which is the only approved vx exhaust.
      Awesome, not so worried about that then, just ring network q and get them to certify if i can fit myself and keep warranty, just wondered if they could tell if the remus was a option extra or not.
      Not noticed the tinny noise until now though, bit worrying, sounds like baffled wondered if my manifold bolts had not been recalled? Might have to ring vauxhall see if it has been recalled or not.
        I think you will find out exhaust will have to be fitted by dealer , turner or any vat registered garage to keep your warranty on the exhaust and items that can fail because of the exhaust. You can not fit it yourself and have your warranty intact.
          Awesome, any idea on the rattle? can hear it most in 3rd gear at about 5500rpm. Might just be the engine, but sounds a bit tinny.
            To see if yours have been replaced, there will be a little dab of green paint as per the following recall notice if your car is within the VIN's
              I cant see green paint on the manifold bolts, but what numbers am i looking for to see if mine fall in that category? Rattle could just be the baffles i think, might just be the engine tone, im not sure.
                I doubt many garages bother to put a green dot. Just call your locat VX dealer and give them your reg and asked if there were any recalls.
                They will tell you if there were and if the repair was done - and on what date.
                Arden Astra VXR
                Stage 2 - 289bhp Blueflame Exhaust & Remap
