How to remove security screws in number plate?
  • How to remove security screws in number plate?
    As above does anyone no how to remove them?
    You can tighten them up but they cant be undone?? Got some new plates i wanted to put on.
    Slightly larger drill bit, and slowly drill the screw heads off, then pull the plates off, if you cant get the studs out then re - drill holes for new plates.
      Easy when you are told how to
      Would like to do more,
        Not sure how they work exactly, but could you not hacksaw gently in to the screw head to create a new slot to undo it with? Only an idea.
        Astra - Power Red
        Courtenay Sport - Stage 3
        NOW: Astra J - White
        Let's see what happens with this one...
