really loud vibration noise under car
  • really loud vibration noise under car
    hi folks! i have recently noticed that when i put my sport button on and give it the beans i find there is a large vibration front the front underneath of the car??? like i say it only starts doing it after i have driven it really hard with sport on then when im stationry if i rev it up to 3k revs its on the drop back at bout 1k revs it rattles the whole car??? does anyone know what this could be? if its doing any damamge? and thrid and most importantly how much its going to cost to fix
    thanks again
    Tom
    Tom, try not to worry about it. It will most probably be a boost hose come off and a simple fix. Do the pedal test and see if you get any fault codes come up.
      no its not a turkey noise its a vibration, the whole car shakes?? and its hard not to with these cars, as everything is so damned expensive! although if i think about it i still have my warrenty till january!
        I've had 'engine' vibration without any turkey noise on mine before and it's been caused by an air leak somewhere, mine was at the throttle body, where a pipe clip had come loose. As you say, you still have your warranty, so maybe best to just let VX have a look at it. Did you do the pedal test anyway?
          yeah got the 42011 code or something like that, its the one for cat infefficiency though?
            Probably the exhaust moved around abit or touching a heat shield. I've got it right now.. Probably just needs adjusting.
            Will get it done next week when I'm in for a service.
            Clique #14
              yeah im in for a service on tuesday may mention it then. thanks for the help
                May be your exhaust heating up and they can expand a bit I've had it where when mines really hot and at the right angle it would catch and vibrate on the rear heat shield
                  as said check see if it touches heat sheild. quite few ppl had that problem. make sure the exhaust is piping hot when you put it on the ramp to look.
