Air Con Leak
  • Air Con Leak
    Ok, so i went to Kwik-fit today to get my air con recharged. so they put it on the machine and the machine has detected a leak and there is no fluid in my car what so ever Does anyone know how much i will have to pay vauxhall or some other specialist to fix this?
    Very hard to answer this question, all depends on where the damage is
      Damn this is going to cost me a small fortune aint it
        u will want to hope its a dodgy pipe or something simple cos otherwise it can prove very expensive to repair !! .. mine wasnt working a few months ago and had it re gased and there was a hole in one of the pipes .. cost me £150 just for the hose !!
        www.thevenuelondon.com / www.myspace.com/fatboyateallthepies
        the owner of the first zaffy detailed by vxrmarc and also the owner of the first bus sm'd by vxrcourt3
          How old is your car ?
          Warrenty claim ?
            if its the compressor then you wont get much change from £1000,drive in drive out at main dealer..but hay it could be just an o-ring at say £100 including fitting and regas..?
              Its a 55 plate so no warranty. I hope its not £1000 i cant afford that kind of money just for air con. If it is that do i have to get it fixed will it mess up anything else in the car?
                nah it wont affect anything else if you dont fix it
                my mate removed his a/c to save on weight as the compressor is surprisingly heavy
                hth
                corsa arctic edition #257
                now sold
                REAR STRUT BAR FOR SALE!
                  Have a look at the bottom of the condenser, the bottom falls off on the 1.9 cdti. Common fault on the diesels.
                    have a look at the air rad mine corroded along the bottom cost me 350 quid at the dealers to fit a new one and pump it back up again.its a common fault .you can look around and fit it yourself .
                    Magnex Exhaust .TXA sports cat,CDTI box,KN air filter ,TXA top hat pipe ,dreamscience handset ,white line rarb ..Now have a Astra j VXR
