Oil Restrictor Bolt
  • Oil Restrictor Bolt
    Was gunna purchase this as per reading about it prolonging the life of the turbo...........
    However I wasnt sure how easy it is to fit and if its trully worth getting?
    http://www.lmfvauxhall.co.uk/Astra-a...ctor-Bolt.html
    Any of you guys/gals had one fitted?
    Moved to Astra chat section
    Astra
      Most do I would go as far as saying. Not from personal experience as I don't have one, but from what I've read they're almost essential for the turbo when running larger exhausts. I'll be fitting one at the end of this month once my warranty runs out.
        http://cgi.ebay.co.uk/ws/eBayISAPI.d...=STRK:MEWAX:IT
        Is the above link alright or as good as the one from LMF Vauxhall (http://www.lmfvauxhall.co.uk/Astra-a...ctor-Bolt.html)
        Just going on price/quality??
          I have one put in long time ago and its similar to those in the two links and it is fine.
          However, if I ever need to buy another one, I would buy one which you can use a socket to do and undo, the torx ones are prone to be rounded, .
