Problem with vacuum pipe
  • Problem with vacuum pipe
    Just wondered if anyone could help me my vacuum pipe keeps popping, it mainly pops off when i have sport mode on and put my foot down. I have tried cable tying it on but it hasn't really made much difference, don't know if anyone has any ideas of what i can do
    Tom
    Debadged, Tinted Windows, Carbon fibre bits, Cobra Exhaust, Rarb, Pro Kit Springs, EDS Tophat, Forge Recirc Valve, Oil restrictor bolt, TXA Intercooler, Pipercross cone, CDTI Hose, KTM Orange Snowflakes - TMS Stage 3 Map 290 BHP and 347 Torque
    I little dap of superglue works.
      just make sure when you glue it you dont block the pipe.
      Clique #14
        You could replace it with 3mm silicone
          Next time it pops off pull the cable tie one 'click' tighter then push the hose back on.
            Cheers for the replys guys, I going to get some glue and hopefully that'll will work. What would be causing the pipe to pop off in the first place?
              They just do, it even happens on standard vxr's.
                As said above i had to keep stopping on a track day coz it kept popping off - cable tie it tight then push on with the cable already tight, i have had no problems since
