Should I do a hard reset before installing a new map?
  • Should I do a hard reset before installing a new map?
    As per title, dreamscience arrived today. Should I disconnect the battery for 20 mins to reset before installing the new map? And if i disconnect the battery AFTER the map is loaded will it take a life to put it back on or will it not be lost?
    no. when the new map is uploaded it will have to re learn the values for fuel trim anyway. will be a clean slate when the new map is uploaded and no need to d/c battery after wards either. maybe disconect it after a few months/weeks to reset trims then..
      When you disconnect the battery the map is not lost. No need to disconnect before uploading the map, as the map will wipe all the learnt values and it will take awhile for the ecu to adjust to new map.
      You only lose a live on the dreamscience when it is connected to another car
        That was fast answering! Cheers guys. All questions answered in 3 minutes! I'll go and plug it in shortly then.
          ^^ what they said it takes a while to upload but worth the wait
            Just plugged it in, it has 3 upload maps on it; ds ultima, ds stragem and ds eph(...) not sure what the last was. Does that sound right? Thought they should be race and race +
              not sure tbh i thought same as you it would be ultima race and race plus pretty sure thats what mine said will go check mine
                thats one of the first models m8
                  yes mine has ultima race and race plus
                    Ok. So you think they're the same maps jigger? It's half way through loading the ultima map
                      yep was just different names im not sure if the software needs updated or will be fine as is but most run ultima anyway so batter on you will be impressed
                        sorry to hijack but mite help the op also but Jigger i see you run the race+ how much different is that from ultima? more aggresive? how much boost does that run?
                          When I plugged it in and looked in device info it said 5 unlocks remaining. The guy said it had 4 lives. Are unlocks and lives the same? If not, how do I find out how many lives it really has left? Can't see it having 5 as he used it on his burg
                            that will change to 4 i think once you have uploaded a map to yours, mine says 5 remaining even tho i have loaded a map
                              As per vauxtilliedie, anyone have of know where to find dyno charts for the same car on the same day tested on each map?
