im eliminated
  • im eliminated
    ok guys im extremely narked now like my head is going to explode ...
    i tried to fit one of those o2 eliminator's and iv epic failed . I managed to get the o2 sensor out , but the thread is K.O 'd i mean mauled! then i tread putting the eliminator on and il give it credit got most of the way in , but then just kept turning and turning ...
    so at this point iv managed to nip the o2 sensor on a thread ...and i mean on " A " thread! im not using the car until its sorted out please i need help with this guys . regards tim .
    ok well you need a new banjo bolt now and im guessing the thread in the cat needs retapping, did it look like it had been tampered with before?
      no ... no way has it been tampered with .
        Youre going to need a helicoil thread repair kit (m18 x 1.5 if i remember correctly) and it will probably require removal of the exhaust so you can get access to repair the boss, then a new bolt and, if the sensor thread is as messed up as the photo above, a new lambda sensor..
          ok cheers bud
            my dad has got a pit at work so access under the car isnt a problem : ) i may get a garage to tap a new thread in as iv never done it before : ( so much as id like to .
              o2 elim?? looks like a oil bolt to me?
                that's just part of it , the bolt holds the eliminator to the cat and lets a fraction of the emissions through . But i guess you already knew that bud
                erm... update yer col it is a oil bolt
                  sorted , I re cut the thread got a new banjo bolt and a new o2 sensor to be honest I was surprise how well the tap bit cut the thread , very clean ... so the burg is up and running . All I need to do now is sort out the headlight . I have opened up a dispute with the seller on ebay through ecc European trading standards institute , so hopefully I can get my money back and get the proper light . Thanks for all your feedback guys . Tim
                    glad you sorted it, did you buy the lambda sensor from that link i sent you? good service?
                      yer i did , really good price and quick delivery cheers bud
                        good stuff think ill get one myself when pay day comes around i still have some fault codes relating to o2 sensors replaced the front one and it still came back so ill change the rear one see if it helps
                          Yer i would do that as well , its not out of the way £65 but all these little payments add up ...so my bank tells me any way hope you get it sorted out buddy . Keep us updated . regards tim
