re map but with less power?
  • re map but with less power?
    my car has just been in for a re map i had it dynod before and after, the before ran 277bhp with 272 ft lb of torque and after ran 272bhp with 360 ft lb of torque surely this isnt right is it? my car feels alot faster in 1st and 2nd gear but slower 3rd gear onwards any help or advice would be much appreciated thanks jamie
    Forge cooler, milly race, stage 3 eds map, dap r's, rarb, cdti kit, forge re circ, wavetrac diff ect ect ect....
    you have gained almost 100ftlbs it should feel much faster
      it does in 1st and 2nd gear but slower in the rest ov the gears it just doesnt feel like the power is ther like it did before
        Do you have the dyno graphs and do they show boost and afr ? do you have a boost gauge? 360lbft of torque doesnt sound right for what i presume is a stage 2 car.
        Your best bet is probably to take is straight back and get them to give it the once over.. who's map is it?
          where did you have it done. 360 seems a bit high, although once i did get 390 at mpg lol. seems a bit odd. last dyno i got 323 and 340 both ftlbs. so depending where you have had it done figures change alot. your map obviously shows a good torque increase but bhp may have already been good on the original map and responsed well to any upgrades like exhaust etc.
          jwfcms
            yes i have the two graphs before and after but not with me at the moment, no dont have a boost gauge in unfortunatly its meant to be stage 3 it was done at mpg
              wich i fink use the eds map's
                Ahh MPG ok . i see now .
                  ohh no what does that mean?
                    There rollers have a reputation for doing odd things occasionally. Your before figures sound about right though.
                      wat about the after figures though, my car was if anything but better afta the map
                        Did you not ask the tuner these qestions when you where on the rollers or before you left the garage ?
                          I would say the after figures should be ignored.
                            what map did he load on the car mate and what mods you got?
                              ignore the torque figures, but at least they have increased alot on the dyno and thats all that matters, on the same dyno, same day etc that before and after were different. dont know why the bhp is a bit less but it could be down to a few little things like where the power is created on the new map, if you havnt got suficient airflow at the higher rpm where it may produce the more power you may loose out?( just a thought something along those lines. id take the figures with a pinch of salt. whats your full spec as we dont know much..
