advice needed
  • advice needed
    after your advise.
    i have just bought my first VXR after makeing the move from impreza's
    i am wanting to know what is best to get on the astra vxr .....
    a full induction kit with cone etc
    or
    performance replacement filter?
    thanks in advance
    T12KY
    cdti airbox coversion. use the search button and it will bring up loads of threads
      id go for a good panel filter, such as ITG, along those lines.
      A good cold larger air feed(which is under the grille, the DBILAS air scoop is massive and get some 3 inch ducting from that to the airbox. keep the airbox closed to draw in cooler air from the outside and less heatsoak from engine bay.
      cdti airbox is expensive and for what gain you get, if any, as its been tested and dont think there was anything in it. id go for panel filter in current airbox with a new large air feed.
        thanks for the replys and i will do a search about the conversion thanks again
