Couple of questions
  • Couple of questions
    Need some quick advice if possible from some of you guys, I am finally fitting my CDTi airbox this Saturday, but need to know when extending the wiring is there any special sort of wire I need to make sure I've got, or will standard speaker wire/electrical wire suffice?
    Also the griffin badge on the front grille does this just pop off or does the grille need removing to take this off?
    Also what is the thread size of the rocker cover bolts?
      Just any electrical wire for small circuits, cut each of the 4 wires and just solder the extension into the wire. You can pick up a real for like £2.
      Then a bit of insulating tape to protect the joins and maybe something to cover up the wires and keep them together.
      Clique #14
        Grille off to remove the griffin really easy job to do.
        Now at stage 3
          The correct wire is automotive cable;
          Cross Sectional Area: 0.75mm (20AWG)
          Voltage rating: 600v rms
          Outside Diameter: 2.8mm
          Current Rating: 14 Amps
          Type: 24/0.2
