boost control solenoid hoses
  • boost control solenoid hoses
    does anybody know the part numbers for new vac hoses for the boost control solenoid?
    Arden VXR, 19" Anthrecite alloys, TMS Stage 3, Forge FMIC, Remus, K&N Panel filter, Insignia washer jets, RARB, DAP's, Sight and light, Keyless, Forge recirc valve, Percys oil restrictor and breather box, 3 Gauge conversion, VXR front grille badge, VXRonline window stickers and The Origional Percys Airbox
    As far as I can tell they aren't available seperately..
      Just get some heat resistant hose that wont suck in on itself and you should be fine.
        i used some 4mm silicone vac hose. never had a prob. also when tested no leaks. no blew off. no clips on either and that was at 30psi. alot of people change them to silicone.
          did you use this for every boost piping ?
            yep. best stuff to use.
              any link's as where to buy this from mate ?
                Cheers for the replies lads. Ayee any links to the vac piping would be appreciated
                  http://www.merlinmotorsport.co.uk/p4...duct_info.html
                  just ordered a length of that so hopefully get it fitted this week
